All Hail Mars!
Re: All Hail Mars!
Allså allt är ju Adeptus Mechanicus, men olika delar. Cult Mechanicus är de som är religiösa. Stora delar av mechanicus är ju robotar etc som inte tror på något, utan helt enkelt bara följer order/direktiv från prästerna.
Re: All Hail Mars!
Re: All Hail Mars!
Så det är vad vi kan förvänta oss under 2015 för mechanicus.
Re: All Hail Mars!
Alltså... Dem battle servitors...
Re: All Hail Mars!
Silvertejp
Silvertejp
Re: All Hail Mars!
Edit: det var samma bild nvm...
Re: All Hail Mars!
En liten sammanställning av "rykten" från Natfka o bols
Kataphron Destroyers (3) 165 Pts
Troops
BS3 WS3 S5 T5 W2 I3 A1 Ld8 Sv4+
Unit Type: Infantry
Equipment: Half-Armor Kataphron, Plasma Culverin, Phosphor Blaster
Special Rules: Song of the Omnissiah,
Options: Add up to 9 additional models @55 Pts apiece
Each model can replace with a Plasma Cannon Culverin Heavy Grav cannon– Free
Each model can replace the Phosphor Blaster with a Flamethrower Cognis – 5 Pts
Heavy Battle Servitors: Models with this special rule can not run, but can shoot up to two weapons to Shoot phase. These models count as stationary when firing with heavy weapons or gusts, even if they moved in the previous Movement Phase, also can charge the same turn in which they used weapons to Rapidfire, Burst or Heavy.
Kataphron Breachers (3) 150 Pts
Troops
BS3 WS3 S5 T5 W2 I3 A1 Ld8 Sv3+
Unit Type: Infantry
Equipment: Armor Assault Kataphron, Heavy Arc Rifle, in Arco Chela ???
Special Rules: Songs of the Omnissiah,
Options: Add up to 9 additional models @50 Pts apiece
Each model can replace the Heavy Arc Cannon with a Torsion Cannon – Free ???
Each model can replace the Arco Chela with hydraulics 10 Pts
Translation of the Equipment's french rules :
Kataphron Assault Armor : save 3+
Kataphron Half-Armor : Save 4+
Arc Claw : Melee, S+1, AP5, Haywire
Hydraulic Claw : Melee, S+2, Unwielddy, At the end of the assault phase, you can do an additional attack with Strenght X2 (max S10)
Cognis Flamer : template S4 AP5 Assault, when used at overwatch, 3 hits instead of 1D3
Heavy Arc Rifle : 36" S6 AP5 heavy 2 Haywire
Heavy Grav Cannon : 30", F*, AP2, Salvo 4/6 Concussive Grav
Phosphor Blaster : 24", S5, AP4, Rapid Fire, Luminagen : a unit wich take a damage or lost a wound by these munitions, take a -1 cover save penalty till the end of the phase. When a unit charge this target, they can reroll their Charge roll
Plasma Culverin : 24", S7, AP2, Heavy 2, Blast, Gets hot.
Torsion Cannon : 24", S8, AP1," heavy 1, 1 Penetrating hit = 1D3 HP lost. 1 wound = 1D3 wound lost. (After Succesfull wound/hit and save failed)
Cult Mechanicus Formations
Cult Mechanicus has 4 formations.
Cohort Cybernetica – all models in the formation are fielded as a single unit and robots can fire at different targets
1 Tech-Priest Dominus-gets the rules for the Cybernetica Datasmith
2 Kastelan Robot Maniples
Elimination Maniple – gain +1 BS and ignore cover
2-3 units of Kataphron Destroyers
1-3 Kastelan Robot Maniples
Numinous Conclave – must have equal numbers of each type of unit gain crusader and re-roll wounds
2-3 Fulgurite Electro-Priests
2-3 Corpuscarii Electro-Priests
Holy Requisitioner – Deep Strike with no error
2-3 units of Kataphron Breachers
Troops
Unit Type: Infantry
Troops
Unit Type: Infantry
Re: All Hail Mars!
En elemination formation kostar lite pts, men fy fan va grav skott utan cover de kan skicka iväg.
Re: All Hail Mars!
Kommer lätt bli en sådan armé! Så jävla snygga!
