systrar i white dwarf
Re: systrar i white dwarf
Jag väntar på de riktiga sidorna innan jag fäller min dom, men ser det ut som det verkar tycker jag synd om alla systerspelare.
GWs psykers kommer höra ett skrik genom abyssen och få ändra allt till codexen sen.
Pete: Pret-ty black.
Ojdå, mycket mer verkar ha kommit upp inatt.
Okej, först det här:
Some little point teasers from the Sisters Second White Dwarf.
Regular Sisters 12 pts each
Cannoness 75 pts base
Coffessor 55pts base
St. Celestine 175 pts
Repentia 90 pts 4 + 1 Mistress
Celestian & Sheraphim 15 pts each
Retributer 85pts for max heavy bolters
Och vad som inte fanns där igårkväll:
A good snposis from Madcow on Heresy of the White Dwarf.
So lets do a round up shall we.
Blessed Banner: 12” re-roll morale and pinning, as long as bearer is alive Command Squad counts as scoring 1 extra wound in cc for assault results.
Chirurgeon’s Tools: Feel No Pain to the unit.
Condemnor Boltgun: Combi-stake crossbow. 24” S5 AP- Assault 1, Psi-shock
Psi-shock: Any psyker that takes an UNSAVED wound suffer Perils of the Warp in addition to any other effects.
Laud Hailer: 12” bubble, any successful AoF, Roll a D6 and if result a 6 you gain 1 Faith Point.
Neural Whip: Power weapon, vs non vehicles count as S8 and roll to wound against the opponents unmodified LD instead of T.
Simulacrum Imperialis: Unit re-rolls failed AoF tests.
Vehicles
Immolator
Inferno Bolts: Re-rolls to wound
Wargear options, items listed after each other cost the same.
HQ
Canoness
Replace boltgun and/or bolt pistol with:
Chainsword
Storm bolter
Power sword, combi-flamer, -melta or -plasma
Condemnor boltun, plasma pistol or inferno pistol
Eviscerator
May take Rosarius
May take Melta bombs
For every Canoness you may take 1 Sororitas Command Squad, does not count as HQ
Only 5 member, 3 Celestians, 1 Hospitaller and 1 Dialogus
One Celestian may take either:
Simulacrum Imperials
Blessed Banner
Any Celestian may replace her boltgun with:
Chainsword
Storm bolter
Heavy bolter or flamer
Multi-melta or meltagun
Heavy flamer
Can take Rhino or Immolator
Ecclesiarchy Confessor
May Replace laspistol and/or chainsword with:
Shotgun, bolt pistol or boltgun
Stormbolter
Condemnor boltgun or plasma pistol
Eviscerator
May take plasma gun
May take melta bombs
For every Confessor, Confessor Kyrinov or Uriah Jacobus you may include 1 Battle Conclave.
3-10 models in any combination, does not count as HQ
Same costs are GK ones
Can take Immolator or Rhino
Elite
Ecclesiarchy Preacher
0-5 choice, does not use up FOC slot but are treated as Elite.
Each Preacher may replace laspistol and/or chainsword with:
Storm bolter
Eviscerator
Celestian Squad
4 Celestians and 1 Superior, can include up to 5 additional Celestians
One may replace boltgun with:
Stormbolter
Heavy flamer
One may replace her boltgun with:
Stormbolter
Flamer
Meltagun
One may take Simulacrum Imperialis
Superior may replace her boltgun and/or boltpistol with:
Chainsword
Storm bolter
Power sword, or combi-flamer, -melta or -plasma
Superior may take melta bombs
Sisters Repentia
4 Repentia and Mistress, may include up to 5 additional Repentia
Mistress may take melta bombs
Troops
Battle Sister Squad
9 Sisters and Superior, may include up to ten additional Sisters.
One Sister may replace her boltgun with:
Storm bolter
Heavy flamer
Storm bolter
Flamer
Melta
One Sister may take Simulacrum Imperialis
Superior may replace boltgun and/or bolt pistol with:
Chainsword
Storm bolter
Power sword or combi-flamer, -melta or -plasma
Fast Attack
Seraphim
4 Seraphim and Superior, may include up to 5 additional Seraphim
Up to 2 Seraphim may replace their bolt pistols with:
Two hand flamers
Two Inferno pistols
Superior may replace one of her bolt pistols with:
Chainsword
Power sword
Eviscerator
Superior may replace her other bolt pistol with a plasma pistol
Dominion Squad
4 Dominions and Superior, may include up to 5 additional Dominions
For every 5 models in the squad, up to two Dominions may replace their boltgun with:
Storm bolter
Flamer
Meltagun
One Dominion may take Simulacrum Imperialis
Chainsword
Storm bolter
Heavy Support
Retributor Squad
4 Retributors and Superior, may include up to 5 additional Retributors
Up to 4 Retributors may replace their boltgun with:
Heavy bolter
Multi-melta
Heavy flamer
One Retributor may take Simulacrum Imperialis
Superior may replace her boltgun and/or bolt pistol with:
Chainsword
Storm bolter
Exorcist
Searchlight
Dozer blade
Storm bolter
Hunter-killer missile
Extra armour
Penitent Engine
Unit Composition 1 Penitent Engine
Options:
Include an additional two Penitent Engines
So lets start with looking at the retardedly bad wargear.
-Any model that may replace bolt pistol with chainsword.
Why the hell would you do this? A Bolt pistol counts as a CCW in assault so there is absolutely no reason what so ever to do this. Sure it’s free for any model that can do this but WHY?!?!?! You lose the ability to shoot before an assault and gain NOTHING!!
Now for the so bad it has to be a mistake wargear.
-Condemnor boltgun
I understand the point of this weapon but why such shitty rule for Psi-shock?
Must me shitty editing as spelling errors and other problems can be found in allot of places.
Grey Knight Condemnor Boltgun
Psi-shock: Any psyker HIT by the stake crossbow shot suffers Perils of the Warp in addition to any other effects.
Sisters of Battle Condemnor Boltgun
Psi-shock: Any psyker that takes an UNSAVED wound from the stake-crossbow shot suffers the Perils of the Warp in addition to any other effects.
Now for some missing wargear choices.
Celestian Squad
Where is the option for every member to replace their boltgun with a chainsword? The only unit in the army where you would consider doing this and you can’t do it. The Command Squad Celestians can so why not the regular ones? So what is the point of the Celestian squad? Why the hell do they cost 15pts each? Grey Hunters cost 15pt each and come with +1S +1T +1I the same amount of attacks base (they come with CCW and Bolt pistol) but Ld8 instead of Ld9.
So you are telling me +1Ld is worth the same as +1S +1T and +1I?
They also get their flamer for free and their meltagun costs 5pt while ours cost 10.
But Celestians may sometimes have +1S and Fearless and have a 6++ save!!
/facepalm, sit down and shut the fuck up you Spheeze Mehreene fanboy!
Blessed Ammo
Where has this gone? Why wasn’t there any special ammo in our list?
Now for some ”wtf?” wargear.
Any unit that can take either a multi-melta or a regular melta, they both cost 10pts. I guess for the Command Squad you’d always take Multi-meltas over meltas as your AoF gives Relentless.
Seraphim Squad
Two hand flamers cost 20pts per model
Two Inferno pistols cost 30pts per model
This looks expensive but the Seraphim pistol rule says they can fire both pistols separately. Does this mean you can fire each hand flamer and inferno pistol? The points cost would suggest this.
Now for the ”Good” parts of the codex.
Saint Celestine
At 115pts she is a real bargain, probably one of the best SC for the points cost in the game. Is this another one of those Cruddace Valkyrie units?
As it’s common for Cruddace to have low points costs (compared to other units in the same FOC slot) for new kits (Valk and Trygons) does this mean GW has an abundance of Saint Celestine models they want to get rid of? Most likely is the answer to this…
Now for ”It could have been good but in the end fails to deliver”
You can give each Celestian a special or heavy weapon and their act of faith gives Relentless amongst other things but in the end the unit will rarely be useful. Reason is there are no models in the unit you want to assign wounds to. If you give the Celestians heavy weapons and put them in terrain the Hospitaller or Dialogus will be the first to die, if you dont give them special weapons the Celestians will be the first to die. For the bonuses they provide the unit is rather useless for combat, the turn you get shot at is the turn you will lose this unit. If anything you would put them in a transport and keep them close for the Laud Hailer bonus or a Banner bonus but other than this the unit is pretty bad. Perhaps 1 meltagun so you can use the vehicles firing port.
Penitent Engine
At 85pts each they are way to expensive, they will never make it into combat because they are too easy to destroy and Rage makes them predictable. At 50pt I would have considered them because they have less survivability than a killa-kan.
Unit Composition says 1 Penitent Engine, options say: Include an additional two Penitent Engines
It does not say anywhere that the PE are in a squadron like it did in the old codex, does this mean that each PE is independent of the others? This would have been a huge boost to them but they will still never make it into combat.
Conclusion
This codex is rushed, it lacks in pretty much every department. Heck even the WD itself seems rushed with spelling errors and other mistakes in almost every unit entry. This seems like something the WD team was told to throw together the day before the issue was to be sent to the printers. It doesn’t explain the spelling errors in the 2nd part though.
All in all the codex is shit, you may try to convince me otherwise but unless the FAQ makes some huge changes, as in a complete rewrite of the codex I see no hope for it. The army lacks variety, every single Sister entry is copy paste of the last with a slight change. Units and wargear is too expensive to be useful, most of the AoF are useless and doesn’t scale with the size of your army. Allot of choices seems to point towards a close combat army but you NEVER EVER want to end up in CC with your Sisters. I get the impression that Cruddace thought he was writing rules for a Space Marine army and not units with human stats.
Postat av TastyTaste på Blood of Kittens
Vehicles
Immolator
HQ
Canoness
Chainsword
Storm bolter
Eviscerator
May take Rosarius
Blessed Banner
Chainsword
Storm bolter
Heavy flamer
Stormbolter
Eviscerator
May take plasma gun
Elite
Storm bolter
Eviscerator
Celestian Squad
Stormbolter
Heavy flamer
Stormbolter
Flamer
Meltagun
Chainsword
Storm bolter
Sisters Repentia
Troops
Battle Sister Squad
Storm bolter
Heavy flamer
Storm bolter
Flamer
Melta
Chainsword
Storm bolter
Fast Attack
Seraphim
Two hand flamers
Two Inferno pistols
Chainsword
Power sword
Eviscerator
Dominion Squad
Storm bolter
Flamer
Meltagun
Chainsword
Storm bolter
Heavy Support
Retributor Squad
Heavy bolter
Multi-melta
Heavy flamer
Chainsword
Storm bolter
Exorcist
Searchlight
Dozer blade
Storm bolter
Extra armour
Penitent Engine
Options:
-Condemnor boltgun
Celestian Squad
Blessed Ammo
Seraphim Squad
Saint Celestine
Penitent Engine
Conclusion
Jahapp. Hej då tjejer. Må så mysigt i garderoben ett par år...
Jag undrar vad som ligger bakom beslutet att trycka listan i WD. Av alla rykten att döma har de ju jobbat med en riktig bok med nya figgar och allt. Det har uppenbarligen blivit ändrade planer. Men varför släppa ett hafsjobb när det finns en fullt användbar (om än gammal) bok? Kände de sig tvungna att ta bort den för att samma enheter inte ska finnas i olika böcker med olika regler?
Nåja. Vi får väl hoppas att den riktiga boken inte dröjer så hemskt länge.
Jag tror att det är det sista i samband med att de inte vill ha kvar några codex från 3rd ED nu när de börjar närma sig 6th ED. En ordentlig systerbok med allting i plast lär nog komma halvtidigt i 6th, men det innebär att de antagligen får vänta i ytterligare 2 år.Anton skrev:Jag undrar vad som ligger bakom beslutet att trycka listan i WD. Av alla rykten att döma har de ju jobbat med en riktig bok med nya figgar och allt. Det har uppenbarligen blivit ändrade planer. Men varför släppa ett hafsjobb när det finns en fullt användbar (om än gammal) bok? Kände de sig tvungna att ta bort den för att samma enheter inte ska finnas i olika böcker med olika regler?
Jag som har längtat så. Låter väldigt oroande.
Nåväl det blir utmanande att spela i alla fall.
Tror att största anledningen till att plocka bort codexet var för att få bort allierade. Väldigt många listor hade en inquvsitor med gammla hooden som täckte hela bordet och två enheter ist för billiga meltor.Seregon skrev:Jag tror att det är det sista i samband med att de inte vill ha kvar några codex från 3rd ED nu när de börjar närma sig 6th ED. En ordentlig systerbok med allting i plast lär nog komma halvtidigt i 6th, men det innebär att de antagligen får vänta i ytterligare 2 år.Anton skrev:Jag undrar vad som ligger bakom beslutet att trycka listan i WD. Av alla rykten att döma har de ju jobbat med en riktig bok med nya figgar och allt. Det har uppenbarligen blivit ändrade planer. Men varför släppa ett hafsjobb när det finns en fullt användbar (om än gammal) bok? Kände de sig tvungna att ta bort den för att samma enheter inte ska finnas i olika böcker med olika regler?
Sen har jag hört att de hade problem att gjuta de nya modellerna.
Christofer "Koftan" Andersson
