Nya Codex: Space Marines
Re: Nya Codex: Space Marines
Släpp termerna FOC och allies så underlättar det en del. Konstatera sedan att en formation innehåller enheterna som anges, varken mer eller mindre. Då är du en bit på väg...
Tack! Speciellt bilden hjälpte, även om Floggers tips också var väldigt bra!
orgasmatron
Faan nu blev de för OP, nu måste jag spela med ngt sämre...Röde skrev:Ancalagon skrev:Precis
Kul med Dreads i units. Nu kanske vi får se fler Dreads på turneringar. Som inte är Orgasmatrons...
Spela Chaos, de har fortfarande de sämre dreadsen.orgasmatron skrev:Faan nu blev de för OP, nu måste jag spela med ngt sämre...Röde skrev:Ancalagon skrev:Precis
Detta är Space marine!
The Skyhammer Annihilation Force comprises:
Two Assault Squads with Jump Packs
Two Devastator Squads in Drop Pods
special rules:
Shock Deployment: All units in a Skyhammer Annihilation Force start the game in Deep Strike Reserve. Instead of using the normal deployment and reserve rules for these units, you can, during deployment, choose whether this Formation will arrive during your first or second turn. The entire Skyhammer Annihilation Force automatically arrives on the turn you choose — no Reserve Rolls are required. Ignf tore this Formation's Drop Pods for the purposes ohe Drop Pod Assault special rule.
First the Fire, then the Blade: On the turn they arrive from Deep Strike Reserve, the Devastator Squads in a Skyhammer Annihilation Force have the Relentless special rule and the Assault Squads can charge even though they arrived from Reserves that turn.
Suppressing Fusillade: A unit targeted by a Skyhammer Annihilation Force's Devastator Squad in the Shooting phase must take a Morale test at the end of the phase on 3D6, regardless of how many casualties were inflicted. If the test is failed, the enemy unit does not Fall Back, but must immediately Go to Ground. If the test is passed, the enemy unit is unable to fire Overwatch for the rest of the turn.
Leave No Survivors: Assault Squads in a Skyhammer Annihilation Force can use their Jump Packs in both the Movement phase and the Assault phase. If an Assault Squad from a Skyhammer Annihilation Force charges a unit that has Gone to Ground as a result of the Suppressing Fusillade special rule, that Assault Squad can reroll failed To Hit and To Wound rolls in the ensuring Assault phase.
special rules:
Aj aj aj
Så det som inte skjuts bort assultas bort första rundan...eller i värsta fall andra rundan?
Tur man har kultister att slänga bort på att stå ivägen, känns som ett måste...
Elevatorlake
Den där formationen är ju galen, speciellt med devastators med grav cannons. Galen...
Är noll ett antal?
Dvs, blir det moralslag även om det är noll casualties?
Devastatorsen kanske missar helt och hållet..
Vart kommer den formationen från?
Edit: Jaha, GWs mongosätt att släppa regler på...:/
Någonting säger mig att 8 gravcannons kommer döda skit, de kommer till och med sätta wounds på demonerKaptenen skrev:Är noll ett antal?
