Idag hölls ett litet slag mellan Costudes nya codex mot Thousand Sons nya codex. De var noga med att inte svara på för många frågor om TS men förklarade en del saker som hände under spel. För er som inte följt med i nyheterna från GW är Mutalith Vortex beast, Tzaangor Enlightened och Tzaangor Shaman nya enheter för TS som alla användes på bordet. Här är vad jag kunde snappa upp:
Legion Trait: +6" range on all psychic powers
Warlord Trait: Lord of Forbidden Lore, knows +1 psychic power
Relic: Dark Matter Crystal, allows the bearer to pick up a unit near him and re-deploy as a deepstrike. Does not count as falling back (so can still charge). One use only.
Psychic Powers:
– Warptime
- Death Hex
- Weaver of Fates
- Prescience
– Infernal Gateway, pick a spot, anyone within an area takes mortal wounds.
– Gaze of Fate, cast on 6 gives you a re-roll later same turn
– Glamour of Tzeentch, -1 to hit on a selected unit
– Temporal manipulation
- Doombolt. Does damage and slows movement
Tzaangor Enlightened, uses bows 6's to hit automatically wounds (this is one of three configurations), has invol save, hits on 3's. "Higher toughness" (not sure higher than what, possibly T 5), unit cap 9.
Mutalith Vortex Beast, has invol save (5+ ?), gives bonuses (one of them is re-roll failed charge), 'explodes', degrades with damage, regain one wound per turn, 14 wounds, 4 attacks (may be degraded?), Strength 7
Strategems:
Veterans of the long war
"Hide in webway" - deepstrike a unit.
Aspiring Sorcerers can take any power they like, also (probably) normal smite
Magnus no longer has re-roll invol save, still has 4+ invol
Tzaangor shaman: Can re-roll failed psychic roll once per game, knows 1 psychic power, has invol save
Thousand Sons förhandstitt
Re: Thousand Sons förhandstitt
Tzaangor Enlightened har normalt sett inte bågar... det är Skyfires som har det, men de kanske har slagit ihop det till en enhet med vapenalternativ istället i 40k.
Ja de sade uttryckligen det. Enheten heter Tzaangor Enlightened och kommer i 3 versioner varav en har långbågar.Yabob skrev:Tzaangor Enlightened har normalt sett inte bågar... det är Skyfires som har det, men de kanske har slagit ihop det till en enhet med vapenalternativ istället i 40k.
Nice. Då har man redan en massa modeller. Ska bli spännande att se vad den tredje blir då det bara finns två varianter i lådan idag. Kanske kan bli en 40k- låda med extra sprue i sådant fall.
Jag håller tummarna för en heavy weapon -variant eftersom vi inte kan ta havoxYabob skrev:Nice. Då har man redan en massa modeller. Ska bli spännande att se vad den tredje blir då det bara finns två varianter i lådan idag. Kanske kan bli en 40k- låda med extra sprue i sådant fall.
Pre-order den 26/1.
18!!! Psychic Powers
Tzaangor upgrade kit (autopistol/chainsword) sold separatly (så nu vet vi vad det tredje valet på Enlightened blir)
Eller 20 psychic powers borde det väl bli med, Smite och Weaver of Fates.
De har sin egen skola, CSM- skolan och, om man är demonprins eller heter Magnus i förnamn, Tzeentch- demonernas skola.
https://www.warhammer-community.com/201 ... ge-post-2/
Föredrar man spawns istället för magiker kan man förstås använda deras strategem The Flesh- change för ett fördelaktigt byte.
