Anteckningar från 'mars' FAQ livestream
Youndi
Inlägg av Youndi »
Följande framkom under livestreamen. FAQ släpps i kväll men sidan har crashat när dessa rader skrivs.
Smite beta rule now official rule. Slight changes: Add 1 to warp charge rather than -1 to roll (to a maximum of 11). Also units of psychers like Grey Knights and Rubric Marines are unnaffected from this rule.
Character targeting beta rule now official (also clarified it only applies to characters with <10 wounds)
Battallion now gives +5 CP (was 3), Brigade now gives +12 CP (was 9).
Any effect that "Ingore Wounds" does no longer stack.
Guilliman now cost 400p
Dark reapers now cost more (no number)
Flying hive tyrant now cost more (no number)
New Beta rules:
In matched play: Battle Forged armies can no longer use Imperium, Chaos, Ealdari or Tyrannids as keyword (no 'soup' within the same detachement). some units such as Sisters of silence are unnafected by this rule.
Fully half your army must deploy on the table (points or pl not units). Also if you "deepstrike" turn 1 you must do so within your own deployment zone. starting from turn 2 you may use your rule as normal. Cult ambush are unnafected from this rule.
daskad
Re: Anteckningar från 'mars' FAQ livestream
Inlägg av daskad »
Som jag förstod det så var det bara första spelaren runda 1 som inte fick deepstrikea utanför sin deploymentzone. Men kan ha hört fel.
Youndi
Inlägg av Youndi »
FAQn är ute nu (länk nedan). Det står "During a player's first turn". Så det gäller båda.
https://whc-cdn.games-workshop.com/wp-c ... 018_en.pdf
Mork
Inlägg av Mork »
edit....hittade svaret...
Mork, the articulate ork!
Youndi
Inlägg av Youndi »
Liten uppdatering. Undantaget från Smite-regeln gäller hela Thousand Sons armén, inte bara Rubric Marines.
Exakt ordalys:
"[...]the psyker attempting to manifest Smite has either the Brotherhood of Psykers (see Codex: Grey Knights) or Brotherhood of Sorcerers ability (see Codex: Thousand Sons)[...]"
"Brotherhood of Sorcerers är TS Legion Trait och påverkar således alla psychers.
