Rykten IG
Silversixx
Rykten IG
Inlägg av Silversixx »
Nån måste börja...
The focus of the new IG dex is troops and so is the only information I have regarding new Dex.
First of all Guard are now 4 points each, but this is the "Ground level" guard so to speak. They can have no Special weapons or heavy weapons at all, in all respects they are the new conscripts but with normal guard stats.
There are several types of Platoon as we have already heard, Heavy Weapons, Forward Team, Armoured Devision, Airborne
In addition, each platoon is able to include 1 supporting unit, and this will NOT count towards the FOC.
The supporting unit varys in accordence to how its platoon is organised.
Heavy weapon platoons may take 3 heavy weapons per squad (10 man squad) but no special weapons, these is a points increase per guardsmen but he didn't reveal these. The heavy weapons platoon may take a Fire Support Squad or a Standard Leman Russ. There is additional heavy weapons being given to the guard which are only avaliable in this Fire support squad and not in the main platoon squads.
Forward Team is able to take 3 special weapons (Flamer, Melta, Plasma, GL) but no heavy weapons, in addition they gain Infiltrate. Their supporting units include Veteran Squad and Sentinel Squad. The Veteran squad also gains Infiltrate.
Armoured devision is mounted in Chimeras. They can take a combination of either 3 special weapons or 1 heavy and 1 special weapon. Their support units are Leman Russ Battle tank and Veteran Squad who must also be mounted in a Chimera.
Airborne I was not given much information about but I am guessing it is deepstrike and probably something revolving around Storm Troopers and Valkarey.
The reason Leman Russ are being included in the platoons as they want to push it being the main battle tank of the Imperial Guard and have it represented so.
En CAD-ad version av den beryktade Valkyrian...
Izin
Re: Rykten IG
Inlägg av Izin »
Intressant...
17,83
Nefrums
Re: Rykten IG
Inlägg av Nefrums »
Det låter ju nice, dax att måla fler guards, 200 kommer nog inte att räcka långt.. :D
PeterWelzien
Re: Rykten IG
Inlägg av PeterWelzien »
Vart kommer den här informationen ifrån?
/Peter Welzien
Re: Rykten IG
Ryktestrådarna på warseer/dakkadakka.
PeterWelzien
Re: Rykten IG
Här kommer ytterligare några rykten från Warseer:
Here are a few rumours about the new IG Codex a friend of mine heard from a local GW manager. I trust him, as he had already provided me with very accurate informations concerning the 5th Ed SM Codex a few monthes ago. We can expect:
-3 Leman Russes per HS slot. Leman Russes can now move and fire ALL their weapons (including the Battle Canon), regardless of their strength. It seems that the designers want to bring the Leman Russ to the foreground...
-New doctrines, including one which provides +1 to cover and allows firing while going to ground.
-New Plastic Command squad.
-Assault 2 Lasguns (not free, though - probably an upgrade).
-The plastic Valkyrie will cost 60€.
-New plastic Hellhound (old news but good news anyway).
As usual, take it with a pinch of salt.
PS: I hope my English wasn't too bad... Don't hesitate to correct me if I did something wrong.
Edit: I was also told that in order to field 3 LR per HS slot, you'll have to meet "certain conditions". Maybe some kind of Tank Commander?
Jag tror det när jag ser det...
/Peter Welzien
Re: Rykten IG
Nej, nej, för i helvete nej!
Ashura
Re: Rykten IG
Inlägg av Ashura »
jag läste nånstans att dom skulle ta bort alla doctorines och istället ge vissa enheterna vissa options som skulle motsvara dom doctorines som finns.
kelaino
Re: Rykten IG
Inlägg av kelaino »
Jag har också läst (bl.a. här: http://commissar.proboards22.com/) om att doctrines ska bort, men "finnas kvar" på platoon-nivå.
Skulle annars gissa att ryktena går heta just nu och man får ta det mesta med en näve salt.
Mathias Lamu
Uppsala - VSSU
PeterWelzien
Re: Rykten IG
I någon IA update så finns det chimeror till Witchhunters som har reglerna Fire Base och Mobile Command Post. Det skall bli intressant att se vad det blir för något.
/Peter Welzien
