Missions
Missions
Inlägg av Jocke Rapp »
Missions finns i bifogad Word-fil eller som svårläst text nedan.
Notera att det alltså inte finns några speciella regler för outscoring utan det är regelboken som gäller.
Battle 1
Deployment: Spearhead
Mission: Seize ground with 4 objectives
Before deciding deployment zone, place a total of 4 objectives on the table. Roll-off to decide who starts placing an objective and then alternate placing the 4 objectives. These objectives may not be within 12” of a table edge or another objective.
To claim an objective, you need to have at least one scoring unit, and no enemy unit, within 3” of the objective at the end of the battle.
Objectives Tournament points
Controlling more objectives than your opponent 10
Controlling the same number of objectives 5
Controlling less objectives than your opponent 0
Victory points difference Tournament points
301- 10-0
0-300 5-5
Battle 2
Deployment: Pitched Battle
Mission: Capture and Control with an extra objective
After deciding deployment zones but before deploying your forces, place one objective each in your own deployment zone. The player that goes first starts placing his objective and these objectives may not be within 6” of a table edge. Also place a third objective in the center of the table.
301- 10-0
0-300 5-5
Battle 3
Deployment: Dawn of War
Mission: Claim Quarters
To claim a quarter, you need to have at least one scoring unit, and no enemy unit, in the quarter. A unit is considered to occupy the quarter where the majority of the models are at the end of the game.
Quarters Tournament points
Controlling more quarters than your opponent 10
Controlling the same number of quarters 5
Controlling less quarters than your opponent 0
301- 10-0
0-300 5-5
Battle 4
Mission: Capture and Control with inverted placement
After deciding deployment zones but before deploying your forces, place one objective each in your opponent’s deployment zone. The player that goes first starts placing his objective and these objectives may not be within 6” of a table edge.
301- 10-0
0-300 5-5
Battle 5
After deciding deployment zone, place a total of 4 objectives on the table. The player that goes first starts placing an objective and then both players alternate placing the 4 objectives. These objectives may not be within 12” of a table edge or another objective. At least one of the two objectives placed by each player has to be placed on the opponent’s half of the table.
301- 10-0
0-300 5-5
SydCon Missions.doc
(34 KiB) Nerladdad 251 gånger
Re: Missions
Uj. Franskt.
Hawk
Re: Missions
Inlägg av Hawk »
Yes franskt! Ser bra ut!
/H
Nefrums
Re: Missions
Inlägg av Nefrums »
jocke hade det inte varigt ballare om man hade fått:
Controlling more objectives than your opponent 46957124797504790
Controlling the same number of objectives 23478562398752395
Jag menar man kan ha det enkelt med 0, 1 och 2 poäng, men det är ballare att omotiverat multiplicera poängen med nåt ball, bara för att det ska bli svårare att räkna.. :P
Annars gillar jag missionsen. :)
Bengtsson den yngre
Re: Missions
Nefrums skrev:jocke hade det inte varigt ballare om man hade fått:
Skitbra ide! och så kan man ha en målningsbedömning som motsvarar typ en whipe dvs 46957124797504790 poäng, snacka om nyanserad skala! Eller så kan man gör på det enkla sättet och ha 2 p för vinst och max 2 p i målning. As enkelt, 1 p för tre färger och ett p för, öh, baser. Asbra!
Jag har ingenting med sydcon att göra men kunde inte låta bli att dryga mig med dryg-jeppa.
Re: Missions
20p per match är ganska lagom, eftersom jag gärna vill slippa använda decimaler för kompen. I övrigt hade det funkat med 0-1-2 ja.
Hylander
Re: Missions
Inlägg av Hylander »
Med mall finns det ju bara två lägen ändå så det kvittar väl ;)
Per Pirat
Re: Missions
Inlägg av Per Pirat »
Bästa upplägget på mission och VP jag varit med om.
Pete: Pret-ty black.
Nefrums
Re: Missions
Inlägg av Nefrums »
en liten sak..
Är det meningen att det ska vara möjligt att lägga de båda objektiven på varandra i mitten i mission 4?
Re: Missions
Per Pirat skrev:Bästa upplägget på mission och VP jag varit med om.
Tackar!
Nefrums skrev:en liten sak..
Nej, det är quarters och därför börjar deployment zones 12" från mitten.
