BlomCon Missions
Moderator: Snot
BlomCon Missions
mission 1:
Deployment - Diagonal Dawn of war: The players deploy on one half of the table, divided by the diagonal. The player choosing deployment zone chooses which corner to base his deployment zone in. Push back 18”.
Reserves can be deployed from both the long side and the short side of your triangle. Fleeing units flees to the closest tabel edge not only your tabel edge.
Primary objective: hold objectives, one objective marker in the center of each quarters,
Secondary objective: Kill the most expensive HQ unit of your choice belonging to your opponent. (Ex. an entire Imperial Guard Company Command Squad needs to be killed, but not their dedicated Chimera)
Battle Points Table
Victory Points
0-200 4-4
201-400 5-3
401-600 6-2
601-800 7-1
800+ 8-0
Primary Objective
(Advantage in controlled objectives.)
12-0 3+
10-2 2+
8-4 1+
6-6 0
Secondary Objective
4-0 is awarded to a player who achieves this goal and simultaneously keeps his opponent from doing so, any other scenario results in
2-2.
________________________________
mission 2
Deployment – spearhead
Primary objective: Kill points
Secondary objective: hold objectives. Two objectives are placed 12” from the shortside 60cm from the longside.
Battle Points Table
Victory Points
0-200 4-4
201-400 5-3
401-600 6-2
601-800 7-1
800+ 8-0
Primary Objective
(Advantage in kill points.)
12-0 3+
10-2 2+
8-4 1+
6-6 0
Secondary Objective
4-0 is awarded to a player who controls a superior number of objectives, any other scenario results in 2-2
_________________________________________
Mission 3
Deployment – Pitched battle
Primary objective: Objectives. Before deployment players (decide randomly who begins) take turns placing two objectives each, at least 6” from any table edge and at least 12” from eachother.
Secondary objective: Destroy/Kill your opponent’s largest model. If there are several models of the same size randomly determent which model to destroy/kill.
Battle Points Table
Victory Points
0-200 4-4
201-400 5-3
401-600 6-2
601-800 7-1
800+ 8-0
Primary Objective
12-0 2+
9-3 1+
6-6 0
Secondary Objective
2-2.
Mission 4
Deployment – Diagonal Pitched battle Players deploymentzones are as illustrated below, measuring 17” along the shortedge and all the way to the secondnearest corner.
Primary objective: three objectives diagonally deployed on the center line of the boards.
Secondary objective: Have more scoring units fully within the enemy’s deployment zone.
Battle Points Table
Victory Points
0-200 4-4
201-400 5-3
401-600 6-2
601-800 7-1
800+ 8-0
Primary Objective
(Advantage in controlled objective markers.)
12-0 2+
9-3 1+
6-6 0
Secondary Objective
2-2.
Battle Points Table
Victory Points
0-200 4-4
201-400 5-3
401-600 6-2
601-800 7-1
800+ 8-0
Primary Objective
12-0 3+
10-2 2+
8-4 1+
6-6 0
Secondary Objective
2-2.
mission 2
Battle Points Table
Victory Points
0-200 4-4
201-400 5-3
401-600 6-2
601-800 7-1
800+ 8-0
Primary Objective
12-0 3+
10-2 2+
8-4 1+
6-6 0
Secondary Objective
Mission 3
Battle Points Table
Victory Points
0-200 4-4
201-400 5-3
401-600 6-2
601-800 7-1
800+ 8-0
Primary Objective
12-0 2+
9-3 1+
6-6 0
Secondary Objective
2-2.
Mission 4
Battle Points Table
Victory Points
0-200 4-4
201-400 5-3
401-600 6-2
601-800 7-1
800+ 8-0
Primary Objective
12-0 2+
9-3 1+
6-6 0
Secondary Objective
2-2.
Re: BlomCon Missions
När reserverna kan komma från både lång- och kortsidorna, så borde det innebära att man även flyr mot närmaste egen kant som i 4th ed.
Men vad innebär det för enheter med outflank? Ingenting?
Hur man flyr har jag inte tänkt på.. men det borde nog stämma, tack ska lägga till det.
outflank funkar som vanligt.
Skulle det inte spelas på 48*48-bord? I så fall stämmer inte riktigt bilderna.
Jo 48x48" bord, är måtten fel mennar du? :O Jag lade up ett 48x48" bord hemma och mätte Vilka mått är det som inte stämmer då? Så fixar jag det.
De ser nog bara inte propotionella ut..., Iom att det är en kvadrat och inte en rektangel ni spelar på.
Så klart.. det tänkte jag inte på när jag snodde bilder ifrån snot..
Ska jag göra mig mödan att måla om alla missions eller är det tydligt nog för er?
nu skall jag inte spela, men på mission 2 kanske du bör rita ut objektiven i kanterna på deploiment zonen. Då ser man att det blir mycket nära, (12 tum) mellan objektiven.. Istället för 24 tun som det blir på 4x6 bord..
Osäker på hur diagonaldeploy 17" blir på kvadratiska bord, men det vore tråkigt om det blir helt skevt...
det blir inte skevt, men det blir 29,2 tum mellan deploiment zones..
