Swedish Comp 40K Main Document - Feedback på V1.0
Re: Swedish Comp 40K Main Document - Feedback på V1.0
1 2nd Exalted Reward (First if army includes a Flying Monstrous Creature)
Antar att tanken är att man inte ska kunna gömma Grimoire på ett flygfä? Om detta är fallet, borde det inte gälla icke-Khorneflygare, alternativt bara om man har flygare med Psychic Powers? Problemet är väl att psyker-flygfän i kombination med Grimoire gör den väldigt stark, inte att den skulle vara för stark på egen hand? Eller har jag missat nåt uppenbart?
Inte bara. Man kan ju använda den på flygaren, men ha den gömd i en annan enhet också.
Question:
1 First Psyker (only own or Battle brother ally) with access to Divination in army. (Only if there is an
Infantry Platoon with more than 3 infantry squads)
does this mean if I only have 3 infantry squads, per platoon, I can have 3+ Psykers with Divination in my Army for 0 Komp? I just do not understand your explanation here.
by the way guys. I am using your Komp in my next League here in San Diego. Once I have the league rules up I will post a link so you guys can check it out.
I'm doing Swiss pairing, Swedish Komp (Cumulative Earned and lost Komp points) with Komp earning during missions, capturing Komp points during the game to use in later games. The mission will be crazy and fun tweaked standard mission with some classic missions from the past added into the 6 week League. It will also be a Points escalation league, starting at 1000pts lists and ending at 2000pts.
OH YEAH! and the whole league will be FOG OF WAR, hidden lists. just for fun.
cheers,
Doug
cheers,
Doug
Yes Dugg!
However, Every other divination psyker costs 1 comp so if you have 3, that's 1 comp.
It sounds awesome what you're planning! Let us know more as the tournament gest along!
Centurions bör kompa 2 om man har en multiple-wound 2+ gubbe med invo i armen..
Sen bör demonerna kompa hårdare..(screamer stjärna bl.a)
Har man 2+T5 upgraden på en commander till Tau så ska den kompa rakt av också... det är den som gör broadsides så innåthelvettes omöjliga att döda.
Ta bort royal court kompen på necrons.. sjukt löjligt kompstraff om man kollar till vad det är för annat som kompar..
Kompa första wave serpenten om tagen som allies eller ta bort första anni bargens minus som ally.... serpenten är lika bra som en annihalation barge..
Stjärnan gick upp ett steg redan. På komp 4 får du in fateweaver+1 Herald med lvl3.
Tycker väl generellt att ni i kompgruppen ska börja tänka:
Skulle vi ta in den här uniten i armen för komp 1.. är svaret: Så jääävla värt det, klart jag gör!! - Så kanske denna ska kompas på ett annat sätt??
Centurions är så sjuuuukt jävla givna på komp 1, framförallt när dem kan ha en chapter master med 2+ längst fram.. (Har ju iron halo i grund, så shield är inte alltid nödvändigt) (Därför ja tycker dem ska kompa 2 med en tank)
2 annihalation barges på komp 1? - Känns ok..
MSS på en dlord för komp 1? Finns väl inte en chans i helvette att man tar de minuset..
Helldrake på komp 1? Givet val.
2+T5 gubbe till broadsides komp 0 - HELT SJUKT JÄVLA GIVEN.. på komp 1 - Fortfarande sjukt värt det.
Lite så... sen kommer ju personer som spelar t.ex SM i komp-gruppen inte vilja att centurions kompar 2.. och folk som spelar Tau kommer absolut inte vilja bli av med deras gratis 2+ ninja tank.. men då får ni andra stå på er.
Puss på er.
Puss på er.
Draken ät nått ni borde titta på som allied. Den är sjukt bra och man kan få in den för en billig cultistskatt. Den borde kompa 2 som allied.
mvh:
Dennis
Dennis
http://www.garagegamers.sePärssi skrev:klart vi gör, jag vill inte vara ensam gris...Denkan skrev:jag vet att ni saknar mig så jag kommer
Kompen kommer iom den nya versionen av 40K att göras om i grunden. Hur resultatet kommer att se ut (som idag, som WFB: s mall eller något helt annat) får vi presentera senare när vi har kommit en bit på vägen.
Så vi kommer inte att uppdatera kompen för 40K version 6 något.
