Coteaz - I've been expecting you (mot icke deep strike)
Gustav
Inlägg av Gustav »
När skjuter (och när mäter man) egentligen Coteaz och hans enhet på enheter som kommer från bordskanten?
GK-FAQ skrev:Q: When are the shooting attacks from Inquisitor Coteaz’s I’ve Been Expecting You special rule fired? (p45)
A: They are fired as soon as a unit that is a valid target is placed on the board. Once the shooting attacks have been resolved, the unit can complete its move. If the unit is arriving by Deep Strike, this will be after the scatter has been resolved.
Av FAQ-texten får man intrycket av att förmågan avbryter movement mitt i. Men när stannar man upp? Normalt sett flyttar man ju inte en modell längs med bordet när man kommer från reserv utan man bara mäter från kanten och ställer ut modellerna där man vill ha dem.
Och triggar förmågan överhuvudtaget om man går in säg 15 tum bort för att sedan flytta 12 tum (jump infantry) och stanna 3 tum från Coteaz enhet?
Exakt wording på förmågan är: "If an enemy unit arrives from reserve within 12" of Coteaz and within his line of sight, Coteaz and his unit can immediately make an out-of-sequence shooting attack against it."
Gustav
Re: Coteaz - I've been expecting you (mot icke deep strike)
Inlägg av Gustav »
Så här löste jänkarna det i INAT FAQ
INAT FAQ skrev:GK.45F.01 – Q: GW’s official Grey Knights FAQ regarding ‘I’ve Been Expecting You’ implies that units arriving from Reserves are placed on the table and then moved, yet this seems to contradict the rules for moving Reserves onto the board. How should this be played?
A: While Coteaz is in play, when a Reserve unit is going to move on from a table edge anywhere near Coteaz, first place the models touching the board edge where they are arriving from, then check range and resolve ‘I’ve Been Expecting You’ (if applicable). After that, continue moving the unit but measuring their total movement distance back from the edge of the table where they arrived [clarification].
Seth
Inlägg av Seth »
Tycker tolkningen i INAT-FAQn är väldigt tveksam i det här fallet. Ger dessutom en jäkla fördel till en redan bra regel eftersom enheten garanterat faller av brädet om man skulle misslyckas med ett morale test efter skyttet.
I GWs FAQ står det ju att man ska göra det så fort enheten har placerats på brädet. Eftersom man flyttar in 'utifrån' så har man inte gjort det innan alla modeller i den enheten har gjort sitt move in på bordet. Att avbryta och ställa upp alla vid bordskanten låter som eget hittepå.
daskad
Inlägg av daskad »
Antigen som INAT säger eller så ska alla ställa sig på kanten av brädet enligt mig!
Seth
Inlägg av Seth »
daskad skrev:Antigen som INAT säger eller så ska alla ställa sig på kanten av brädet enligt mig!
Är inte det vad INAT säger?
Kanske förvirringen hänger på formuleringen här:
Move är inte exakt samma sak som movement. Är det t ex ett fordon som flyttas in kan det handla om att lägga smoke, disembarka trupp, ramma eller tankshocka.
uh... där gjorde ju GW regeln krångligare än vad den var innan...
cadelin
Inlägg av cadelin »
Jag skulle säga som INAT.
I GW FAQ står att de ska komma in på brädan, bli beskjutna och sedan göra klart sitt move, det är ju det som står i Inat med.
Mot deepstrike måste gws faqformulering göra att man bara behöver döda en modell för att tvinga hela enheten till mishap. Direkt efter scatter blir juh innan man sätter ut ringen med kompisar. Finns det ingen kille kvar att ställa sig i baskontakt med så kan man inte ställa ut gubben och sådant leder till mishap.
cadelin
Inlägg av cadelin »
men alla gubbar placeras efter scatter sen skjuter man. En gubbe är inte en hel Unit.
Seth
Inlägg av Seth »
cadelin skrev:Jag skulle säga som INAT.
Kommer in på brädan gör man med hela sin tillåtna förflyttning, man ställer inte upp enheten vid kanten för att sedan gå in. Kan ju få den absurda situationen att enheten eller modeller förstörs då de inte kan placeras vid den punkt på bordet där man tänkt att gå in.
